Discuss Switching of suspended dimmable led fittings in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I am installing 12 x suspended LED fittings in an office. They are on two switches. The fitting itself comes with a 5 core cable. How do I switch this. Do I need on/off and momentary switch or something else. See attached pic. Any ideas gratefully accepted.
as above.you will need a 5 core cable to the switch, which will be on/off with a variable 0V -10V output.
Thanks for quick replies.I thought as much , I wired the lights with 3 core cable plus a cat 6 for the dimming control. My problem is that the switches for the lights are on a grid. In the past when I’ve dimmed fluorescents before I’ve had a permanent feed and neutral to fittings and a momentary switch for the dimming control. This doesn’t appear to work on my dimmable LEDS . Does each switched run need two switches, an on off then a separate 1-10v dimmer. I have a 4 gang grid switch and was hoping to just use up two places.
Thanks again for all your help ive found what i need. Its a varilight
Product Description: 2-Way Dimmer for Multiple HF Ballasts/LED Drivers requiring 1-10V DC Input (To fit MK, Schneider Ultimate, Schneider Lisse, Crabtree, Hager, Deta, BG & Varilight PowerGrid)
Reply to Switching of suspended dimmable led fittings in the UK Electrical Forum area at ElectriciansForums.net
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
The following light fitting from Dumelm takes GU10 but states "Dimmable No" but I can't see why with the correct dimmer switch and dimmable GU10...
Hi all, I am trying to replace my halogen wall uplights (230W, 240V, R7S, 114mm) with LED but so far no luck. I've tried both of the below LEDs...
