E
ed-ectrician
Caveat: I am at college doing 2330 and shortly to do 2356, not a Electrical Trainee 'pretending to look at my own CU to get an answer off you lot" - seriously!
So... I look at my CU in rented flat (very nice landlord - happens to be my dad!) after putting in an unfused spur and doing the ring polarity and R1+R2 etc testing. I was a bit surprised to see that the cable going from the DNO isolator (after the meter of course!) to my main intake on the CU looks like 6 or 10mm T&E! hmmm, it's lasted bloody ages but that must have to be 25mm cable surely?! Also my main earthing conductor going from earth bar in CU to MET should surely be 16mm too?!
Am I missing something or is having vastly too small T&E cable carrying all my current just outside my daughter's room as dodgy as it looks to me?!
So anyway, the main service head is on the ground floor (block of three flats converted from Victorian house) and my CU is in the flat on 1st floor. That's gotta be about 8 meters. Is there anything wrong with using 25mm cable to do this upgrade. I calculated voltage drop as ... 1.8 mV/A/m (from table 4D1B) multiplied by 'pessimistically large to be on safe side' 100 amps multiplied by 'pessimistically large to be on safe side' 10meters divide by a thousand to get back to volts from millivolts = 1.8 amps volt drop - which is well within 5 percent parameter?! Pls correct me if I am wrong.
Do I need to stick any double pole isolator or protective device between the isolator already installed and CU? Didnt think so but not sure if there's a reg about that kind of length needing another isolator or fuse?!
I will be running it in trunking up surface of a wall and then thru a couple of joists under floor (>50mm from top and bottom!) then surface trunking up to the board
Ed
Ed
