Discuss Taken down wall lights, nothing else works in the Lighting Forum area at ElectriciansForums.net
I once left an earth communing block at a friends house after doing him a favour.
He later decided to use it as a connector block because it looked similar, joined N L E together trying to extend a cable.
Failed the BANG TEST!!
How we laughed!
I thought the Op was a wind up, right from the start...
yet...some of us have been there, or very near...
I really though i had pulled one night in a cool bar...
minutes later "Lola" by the Kinks came to mind, and i nipped out smartish...
[automerge]1591913371[/automerge]
her terminals didn't match up with mine...
Main switch off then pull the carrier down from the top. If they are mis labelled it's not fun to try and remove the fuse under load.
So I'm told.
The MEM carriers just pull out rather than being hinged at the bottom like the Hager ones.
Reply to Taken down wall lights, nothing else works in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
