Discuss test and certifying... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Are you talking about a PIR inspection? Or do you mean testing the circuits from the CU and putting readings on an EIC? Because you're not really meant to do that!
No, you've misunderstood. Ive had an NIC bloke quote me a periodic and certify the electrics are ok in my house. How much would u charge 4 it?
Reply to test and certifying... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Refurbishment of dwelling has taken place and the clients insurance company requires a periodic inspection and test to be carried out, A new...
This is probably an easy question for an electrician but I was just curious about the theory. (I'm trying to figure out how things work!) I read...
I place the battery on the charger and it is green for about 10 seconds, then flashes red. I placed the same battery on my kobalt 18-20v...
