Aico 3000 Range
Advertisement - Content continues below
Discuss Testing Electricity Meters in the Electrical Forum area at ElectriciansForums.net
I have been asked by the owner of a caravan site to go round and check all the meters onsite to make sure they are working properly. Has anybody been asked to do this before? What is the best way to test them? I was thinking to plug something in which has a big load and watch the numbers going up?has anybody any other ideas?
Cheers
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Spoon
Mentor
I'm keeping an eye on this one as I'm interested to see how its done and if there is a special way of testing them.
I'd just plug in a heater at home for 10 mins and see what reading I get on the meter. Then I'd do the same in each caravan and see if I get a similar reading.... or is there more to it??
Charlie_
Calibrated ammeter and volt meter.
Plug in s fixer load, test the values, with out power and check it against the kWh meter
James
Mentor
Supporter
When he says he wants them checked to make sure they are working properly, is this that he is concerned some aren’t working at all or is he after a calibration certificate for each so he can bill from the meters? You can rent load banks that have calibration certificates.
  • #6
I think he just suspects some of them aren't working correcctly, he doesnt need certs or anything.
  • #8
Thanks for the replies, could you just use clapm meter and heater for a load, then calculate the kwh, from the ampage on clamp meter?
PEG
Mentor
I would imagine,a proper test would include a range of loads,from smallest,to largest. This was common with meters of old.
The biggest error with mechanical meters,was their inaccuracy at lower loads,therefore not recording the majority of a days use.
I know of many properties,where you can stick on most of the downstairs lights,LED's,i know,but the meter wheel remains frozen:)
Alot depends on how accurate you want to be with the test... it's very easy to check it within say 10%... harder within say 5%... and I would guess some very controlled bench testing to get it less than 1%
PEG
Mentor
Just a quick calculation,shows a 1% error,as in 1A on 100A supply,is £250 over 365 days.
It would be this type of error,which accrued costs in either direction,not the short burst of kettle/shower use :)
Wetroom Store - Network Wetroom Suppliers
Reply to Testing Electricity Meters in the Electrical Forum area at ElectriciansForums.net
Aico 3000 Range
Top Bottom
