Discuss Thermal insulation covering cable in the UK Electrical Forum area at ElectriciansForums.net
conrad
I'm doing a garage conversion. 70mm insulation on block then an inch gap battened on top, then 35mm insulating board. Where's best for the cable to go in terms of derating etc...
Cheers.
probably on top of the lower insulation so there's a 1" airspace above. what is the cable/s feeding?
This is on the walls so feeding everything.
ELEC htrs, shower, water htrs, lighting power
. Just think that gap will be the warmest place?
The gap may be warm and you'll need to factor this in to your cable sizing calculations, but you need to avoid putting holes through the insulation as much as possible to avoid compromising it so in the gap is probably the best place for the cables.
Reply to Thermal insulation covering cable in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hey all, Ive been in and out of a huge house rewiring as the renovate it for a year of so. Every is thing done and dusted except the downstairs...
Hi, The current carrying capacity tables in the BS 7671 for twin and earth cables are only for buildings that have thermal insulation. I'm...
4K
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
