Discuss Timer extractor fan in the UK Electrical Forum area at ElectriciansForums.net
SdfEssex
Hi
I've just replaced a non timer fan with a timer fan and the timer fan will not come on.
Original set up.
Wall switch to isolator to fan.
The non timer fan only used the brown cable and grey (w/blue sleeve) cable. Earth and black (w/black sleeve) cables present but left redundant - I assumed this was left as a switched live for later use.
New set up.
Live: brown to Red
Neutral: grey (w/blue sleeve) to blue
Switched live: black (w/black sleeve) to black
Results when testing
Live - signal
Neutral - hard to test as its so close to live
Black - no signal.
I've removed the black wire to see if that was causing the problem but fan still doesn't work. However, when removing this wire and then testing it produces a signal.
I also changed over live and switched live but that produced no results.
Not sure if the following information is useful but when i tested the isolator switch only the the brown wires produced a signal on my tester. The black wire was dead.
Any ideas whats going wrong? I guess I could test the fan with a corded plug and wire up just the live and neutral to see if the fan is working or not.
Thanks for any help.
Cheers
Just a guess but the black wire may not be connected up at its source which is usually the light in the bathroom. I would suggest you follow safe isolation procedures to potentially check this out but only if you are comfortable with knowing what you are doing.
Thanks for the help.
Thought it was going to be a simply switch for the new one but I'm not going to mess about to be honest and I've just contacted an electrician that I use to check wiring.
Cheers
Reply to Timer extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi, changed a bathroom extractor fan. Easy enough. I was dealing with a grey, black, brown and earth wire. When i tested the black wire, which i...
