- Feb 6, 2012
- 11,120
- 8,513
- 165,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Heavily Qualified Electrician / Teacher / Tutor - etc
any body fitting out side lights with dome nuts on the front , and the bolt keeps going back to the wall on some light fittings .a tip for you rip a piece of carboard off the box that it came in, stuff behind the bolt head at the back and hay presto .the head will not move back .
