Discuss Trianco Eurostar oil fired boiler - amber light in the Central Heating Systems area at ElectriciansForums.net
W
wingers
Hi
I have a trianco eurostar oil fired boiler, all has been working fine and it has been serviced this year - but last few days it hasn't fired up and when I take front cover off it has an amber light on and I have to push the light/button to get it to fire up, it is then okay again for a day or two before exactly the same happens again
Any ideas/clues as to what I can do please?
its going into lockout is it the light on the boiler control box or the light on the burner unit at bottom of boiler (usually red) if its light on boiler then there is something wrong with the system ie the pump is not working so boiler getting to hot to quickly and locking out,boiler stat not working same result if its light on burner unit then you have a fault in your burner unit ie electronic control unit,photocell or thermocouple sometimes all three are at fault.
Reply to Trianco Eurostar oil fired boiler - amber light in the Central Heating Systems area at ElectriciansForums.net
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
It has become a common occurrence that my boiler is failing to respond when the thermostat kicks in. I hear an audible click from the heatlink...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Hello, I am in the process of conducting an investigation on a heat trace that was found on fire. The jacket around the wires could have been...
