Search for tools and product advice,
Discuss tt earth rod. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
keniff
hi guys i dont do alot of work on tt setups in my area, just done a few bits, new ring and lighting circuit for an extension, do i need to include earth rod resistance on my eic? thanks in advance
That depends on how you measure the Ra....most use a loop impedance tester and test at the CU as you would for any Ze, this then is obviously your Ze for the install.
If you do a proprietory test with an earth electrode tester & current and potential spikes (difficult in a domestic install in a street) the Ra will be different to the Ze you would do due to the natuer of the test and instrument used etc, although not much.
Either way the Ra is recorded as the Ze for the install.
Reply to tt earth rod. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, just a quick one on an earthing arrangement for a radial circuit on a wooden workshop I have just had installed. I have run a 3 core 2.5mm...
Hi. The question is..... can saturated ground affect earth resistivity testing equipment? Some days there's an unacceptable earth reading, another...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi, Posted here as I'm not an electrician, not because it relates to anything I'm considering "Doing Myself". My late parent's house is supplied...
Afternoon all I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system. Current issue is earthing...
