Discuss Types of crimps. in the UK Electrical Forum area at ElectriciansForums.net
If you are talking extending ring final 2.5mm or lighting 1.5mm circuits i often use ideal wire connectors similar to the wago ones and inclose in a wago type enclosure?
I feel they offer a cleaner connection than that of a crimp.
I would use metal crimps and then heat shrink over connections, then i would use self amalgamating tape to offer extra protection.
if i have to do it , then insulatef through crimps. heat shrink each joint, then over heat shrink or self-amalgamating tape over the lot.
They are commonly called ''Butt Crimps'' or Through Crimps''!! You will need a half decent ratchet crimping tool to make the joints maintenance free. Do not use those pressed flat plate multi function jobbies you get for a couple of quid, they are next to useless and will not give you a sound crimped termination....
Reply to Types of crimps. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
Hi what cable make and size would be needed for hikvision cctv cameras 2.8mm model number DS2CE72KF3T-E picture provided
I had a consumer unit replacement today. It was a bit of a nightmare as most of the cables were too short for the new unit. I extended the ones...
5K
Hi, the new lights I have are metal and the earth connection doesn't connect to anything. I noticed the light that was there before someone had...
