Discuss What kind of earthing is this? TN-S? in the DIY Electrical Advice area at ElectriciansForums.net
looks like it to me to be honest, at least the original braid is in place, I have seen bonding clamps around the sheath many times and the ZE reading poor, have you tested this out of interest to see what the main reading is?
Thanks folks!
@MDJ How do I test this? i.e. what am I measuring for/setting on the multimeter?
A multi meter not the right bit of kit for this, you are looking for a reading in Ohms and via a multifunction tester or loop impedance tester, I have also just realised this is the DIY forum so apologies for my original reply.
Reply to What kind of earthing is this? TN-S? in the DIY Electrical Advice area at ElectriciansForums.net
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
I've tried to understand one way or another but this seems to be connected to the DNO fuse/cutout, and then loops down (out of sight) and comes...
Trying to understand why car chargers attract this earthing ballache. from what I learnt it's all about the rare times a Neutral / PEN conductor...
I am installing a Victron Quattro in an island mode configuration (in the UK, the DNO is the NG). I will be adding a stand-by generator. My...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
