Discuss What to put in your continuity box. with NO CPC around in the UK Electrical Forum area at ElectriciansForums.net
Kyran
HI all
Am i being thick here or Ive got to be missing something.
When your faced with lighting with no earth client does not want to rewire as the places is nicely decorated, and they can’t afford the extra cost. How do you fill in your certs.
eg. fit new SELV down lights to bathroom on pre-existing wires and wholes. but as theres no CPC you can’t do a continuity. As you just have line and neutral on the circuit. So what do you put in the R1+R2 or R2 boxes. if don’t have anything to measure?
Now i know theres no regs that force a rewire and building regs only say that you cant leave the job no worse compliance then before the job. As well as not having any other class 1 or metal accessories. and your main earth is appropriate size, as well as main bounding.
How do you then comply and cert your work. I get that yes you sticker the board saying that no metal can be use on X lighting circuit and the risk assessment is done. but still what do you put in the continuity box on your cert.
Make a note on the cert that the lighting circuit has no cpc and that you have advised the client that only class 2 fittings are to be used
what he said ^^^^^. and now i've got to rattle the brain cells and find something to disagree with archy on. :49:
HI all
The only test for that circuit is I/R L-N before any loads connected & RCD. Just write it up as it is and put N/A for R1+R2 & Zs.
Reply to What to put in your continuity box. with NO CPC around in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
I am doing a new consumer unit install on a second story ex council flat. I’ve notice the mains come in in metal conduit with no CPC. On checking...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
