G
greenm4n
Hi - I'm a newbie on this forum so go easy on me!
I have an install where the customer has specified ceiling mounted light fittings, (e.g. bathroom-type fittings).
The fitting only has single Live & single Neutral terminal.
i) Where do all the other connections go?
ii) Is it right to just use connection blocks + PVC Tape & push into the ceiling void?
Currently in install has been wired in the normal way for domestic lighting, (e.g. One cable to previous fitting, One cable to next fitting and 3rd cable to Wall light switch.
iii) Is there a better way to wire a lights circuit when most of the lights are without pendant fittings?
Steve Shaw
(still to work out his catchy signature!!)
Steve Shaw
