Discuss Zs values? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bs7671
Hi there I have another question for you guys.What is the maximum Zs values for different circuit breakers i.e type B,C,D also where would we find them and why the difference?
the difference is due to the different characteristics of the breakers. the Zs max. is the max. you can allow for the particular breaker to disconnect in the permitted time
I want to find a table or something so I can see the Ka ratings as per different device type.Or at least someone to explain it in simpleton terms
It's the 'on no trip' bit that you need to question.
Most no-trip readings are much higher than conventional Zs readings using a full-current test.
There's also a chance that the RCD is distorting your reading.
New posts
Reply to Zs values? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
So I’m doing my level 3 design project at the moment, and I’m on the question where you do all the calculations on each circuit, I’ve taken the...
I am a lecturer teaching electrical installations and in reading through the on-site guide to prepare a lesson I have come across a section I have...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi All, Can anyone help with calculating a Zs value for the fuse described in the title. The fuse sizes in Fig 3A3(c) of the 18th edition wiring...
