Gross cost to the customer it's £120 per hour. Whether he makes that in his pocket is another thing.
Ok, I see where you're coming from, but hourly rates aside, the point I was really trying to get at was the lack of testing and the precedent that is set from the customer perspective in terms of time and price.
How can you counter that kind of perception?
Reactions: JK-Electrical
Educate the customer.
Tell them, whilst it's just changing out a faulty outside light, it comes under noticeable works as its outside.
So I can do the work and issue you with the paperwork or you can get someone else to do it and not bother issuing the paperwork.
But if the LA found out, you and/ or your installer could be taken to court.
Then wink at them and say a lot of reputable sparkies are actively reporting cowboys who carry out uncertified works.
^^ depends on the customer. If they want out cheap no matter what there is not much that will sway them..... Until they come unstuck with some cow boy
Don't get me wrong. I think all sparkies have done the odd job which should be notified, but didn't bother. Eg, my daughter's outside light wasn't working. I tested it, then replaced it with a new one.
Now I know there will be readers cussing in disgust at me.
Sue me!
been out to two EICR reports last few months both for people buying a house, well first 12 circuits 3 tested rest dashes throughout of the 3 the oven was one & the switch had not been removed as when I did the tiling dust & build dust all fell out & you could not move the range unit on your own.
the other only over weekend 7 circuits 3 tested amazing on sockets had a r1&r2 +r2.
limitations & same dashes all over the place claiming 10% on each.
I had to re-test 1st property when I looked in a side cupboard in eaves a batten holder had been removed & just a piece of loose tape on the live & N hanging free.
not even a mention.
my client paid me £150+Vat & found about 12 C1's.
this was family & the owner who had paid for the test could not believe it.
lucky people moving to the new bungalow will now be using my firm & are already talking about full rewire, they were new to the area 4 years ago had a rewire to the house when they moved in from a company from where they used to live.
this time they were going to use the chap who had completed the EICR on the property they were moving too until I asked if I could look at the cert & when I did I found same rubbish.
this bloke is doing me loads of favours keep up the good work.
I reported the first one for customer as they were really ----ed off & got well not sure what we can do, I was not even going to give out the NIC number but even with that they were not that interested.
A classic case in point; Did some track lights in domestic, showed customer wiring to downlights. They were appalled, the "builder" did it. They said they should have got a proper electrician in the first place. Of course they should. Rewired the whole lot, i.e. tracks and four downlights. And for those of you who are going to say it...that was the wiring before I intervened! It's all tucked up in lovely wago boxes now:cool:TrackRos.JPG Didgeredoo.JPG
Sparkychic there's one thing in those pictures which would have got me told off when I was an apprentice, not flattening the vertical lugs in the single boxes before fitting them.
Thanks, but can I ask... any particular reason? I've never given them a second thought.
Reactions: Joseph Elliott
Yes, it gives you just that little bit more space when fitting the accessories, the unwanted lugs can have sharp edges which are not good if conductors end up pressed up against them.
Not such a concern with light switches but for a sfcu or DP switch every little bit of space can help.
With some makes of accessory you get terminal screws which are scarily close to those lugs if nor flattened. And some flat plataccesories even have a little label on them telling you to remove the top and bottom lugs before fitting them.
Good advice, thanks. Probably second fixing at the weekend so I'll give them a little bit of TLC :)
Electrical installation work, as all self-employed electricians will know, is a highly-competitive business. My own business operates mainly in the greater Glasgow area, and I have to say that I'm finding it increasingly difficult to compete on a level playing field.
I was recently approached by a builder who enquired as to what my fee would be to carry-out an EICR and some PA testing in domestic properties. I told him that I charge £100 for a one-bedroom house, £125 for a two-bedroom property, and £150 for a three-bedroom. Inspection and testing of outbuildings incur an additional fee. Imagine my surprise when he told me that my prices were "way too much". Imagine my further surprise when he told me that "the young electrician" that the builder currently uses to carry-out EICRs charges a flat-fee of £40. Aye, you read that correctly, £40 for an EICR regardless of the size of the property. My response was that I couldn't possibly compete with such a ridiculously low price unless I was willing to work for around £8-£10 an hour, or was willing to cut corners to save time, neither of which I would even begin to contemplate.
I occasionally use MyBuilder as a source of generating business, particularly during times when business is slack. I recently received a lead through the site inviting me to quote for a consumer unit upgrade. Upon contacting the customer to further discuss, the very first question that I was asked was the inevitable "how much is this going to cost me?" I told the customer that although I could provide an estimate, I could not, however, provide a fixed-price quotation prior to me having visited the customer's home and completed a survey. The customer responded by telling me that "all the other electricians I've shortlisted have given me a quotation so why can't you?"
I then explained to the customer that I was somewhat surprised to hear that electricians would even think about providing a fixed-price quotation for a consumer unit upgrade without having first attended the property and carried-out the requisite inspection and testing that needs to be done prior to a consumer unit replacement. The customer was having none of it. They wanted a price there and then. I once again reiterated that I could provide only an estimate at this stage, and told them that the work would cost anywhere between £250-£400 depending on a variety of factors. Imagine my astonishment when the customer told me that they had been given a fixed-price quotation of £200 over the phone by a "nice young man", and that they would now be offering the job to the comedian .... sorry .... electrician who quoted that unrealistically low price.
These two examples are but the tip of the iceberg. There are plenty more that I could cite. What particularly disturbs me is that it isn't "Dave down the pub" who is undercutting me, but young electricians who have not long completed their training. I just can't compete with the insane prices that these young electricians are quoting, particularly when some of them are evidently not even bothering to carry-out any essential inspection and testing before issuing quotations.
My gut instinct tells me that such scoundrels are most likely still living at home and being propped-up by 'the bank of mum and dad'. Perhaps the fools erroneously believe that the way to get ahead in business is to ruthlessly undercut everyone else. The strategy of a newly-started business using 'loss-leaders' as a means of winning customers is one thing, but I don't see how such a business model can possibly be sustained indefinitely. The end consequence of people quoting absurd prices is that a race to the bottom is instigated. It's a race that I have absolutely no intention whatsoever of ever participating in.
I'd be very interested to hear the views of other forum members regarding this issue as I'm sure plenty other electricians will have had similar experiences of cut-throat competition negatively impacting on their own businesses.
The last 3 yrs have had a number of bad installs all from NIEC reg companies. I wonder if it's due to Part Pee and our pretend electricians. During work I was asked to fit new metal light fitting, fitted and checked out earthing ! oops no earth. New C/U had been fitted by local company. Found this pic. Doubt if any testing done.
Thank you all for your replies.
My lingering suspicion that the domestic market has been distorted has now been confirmed beyond any doubt. I'm now considering my position and am contemplating whether I should quit using MyBuilder altogether but remain in the domestic market with a revised marketing strategy, or whether I should just quit operating in the saturated domestic market altogether and leave the new breed of younger electricians to fight among themselves for jobs. I'm leaning heavily towards the latter course of action.
To demonstrate just how bad things are, I've attached a screenshot of a job that was recently posted on MyBuilder. The job was to remove an existing light fitting and fit a replacement. Nine people declared an interest. FFS. Nine electricians competing against one another for a small ten or fifteen minute job.
I won a job last week on MyBuilder to rewire a garage which I completed yesterday. While chatting with the customer, she revealed that from an initial pool of six interested parties, two were shortlisted. I was horrified to discover that the other (young) guy had quoted the customer a price over the phone without having first surveyed the work. I find it absolutely incredible that anyone purporting themselves as an electrician would not bother to inspect the existing installation. What if there was inadequate earthing and/or bonding? What if there was no RCD protection present? What if the garage required a TT earth?
Needless to say, my competitor's price was cheaper than mine. Indeed, my price was £350. His was just over £200. But he didn't get the job because I made sure that the customer was made aware of the requirements of regulation 131.8, and that by not priorly ascertaining the condition of an existing installation that he was hoping to make additions and alterations to, my competitor was willfully not complying with the requirements of BS 7671. One must wonder how many other regulations he considers to be inapplicable to himself.
Unfortunately, this (sharp) practice is commonplace on MyBuilder. Standards are being compromised right, left and centre. Sad but true. The race to the bottom continues unabated, but it's a race that I certainly won't be entering.
whether I should just quit operating in the saturated domestic market altogether and leave the new breed of younger electricians to fight among themselves for jobs. I'm leaning heavily towards the latter course of action[/QUOTE]
I'm a young electrician myself and I fully understand the dangers of going in disgustingly low to win jobs (undercut others) for work.
It de-values our skill-set and gives customers a false sense of pricing. Both of which are dangerous for the growth of our trade.
I like to think I keep my prices up with most of the sparks around my area. ----es me off royally knowing some little turd-burglar is nipping round changing lightfittings for a tenner, and doing C/U upgrades for £100.
I find on these forums,probably because many electricians are self employed.quite a high proportion tend to vote Tory,yet in this thread there seems to be little regard for the most treasured of their values,its called free enterprise
Someone wants to spend the least amount of money,another person wants to provide that service,they may go in as low as needs be to win that contract,consequently the more expensive (or less efficient in Tory speak) they go to the wall
I know the resentment against these instant sparks is widespread however, We have a cut throat way of running an economy and some would say a foolhardy attitude by those who govern,but who votes for these fools ?
You reap what you sow, then you find the vegetation inedible
Reactions: TFGtv
This "grandad electrician" was once a young electrician, but that was a long time ago lol. I'm now in the twilight years of my career and probably have about six or seven years ahead of me before retirement beckons. On the one hand, it saddens me to have witnessed such a sharp decline in standards in recent times, but on the other, it's good to see younger guys like yourself adhere to high standards and not prostitute yourself by selling yourself short. Good on ya!
Reactions: Octopus
Well, I certainly don't vote Tory. Indeed, I don't vote at all. Never have, never will. I consider voting to be a completely futile exercise given that "the man in the street" has his pants pulled down and gets royally shafted regardless of which particular political party is in government. That said, if embracing a market economy would make me a Tory, then a staunch Tory I am!
My gripe isn't about being beaten fairly on price, it's about being unfairly beaten on price. Big difference! I resent losing work to competitors who offer cheaper prices only because they are willfully not complying with the requirements of BS 7671. I have no problem whatsoever losing work to bona fide professional electricians whose work complies with the requirements of the big yellow book. What's the point in having wiring regulations if renegade electricians can act with impunity and decide for themselves which particular regulations they are going to ignore so to undercut their competitors?
Reactions: SparkyChick
The free enterprise economy is the overwhelming reason that this is so prevalent
If a socialist government were in power and making another absolute mess of trying to address this sort of problem (eg Part P) it would soon be accused of interference in business matters,swamping the economy with endless regulation and stifling business interest
Messed up attempts at regulation have made the problem a hundred times worse than before government foolishly interfered with the matters of competence in domestic electrical installation
I agree it is annoying when idiots are in competition with well trained electricians and taking work that they are not competent to carry out,but its the "customer only" who is responsible for that situation
We live in a world where price is the main and often the only concern of a customer
Some will manoeuvre their way through the minefield,avoid the chaff and employ sparks who are well trained,they may get an assurance of quality via their enquiries
Others will employ the man from the pub,the kitchen guy or the guy who thinks its simple but has no clue
Its the customers responsibility to try and ensure he gets what he pays for
Regulatory attempts have been so flawed the chances of the man in the pub having more competence than the registered spark is not so big a bet
The problem is something that is a consequence of the market place economy and the market place itself decides who will and will not obtain work
Domestic work, anyone and everyone dabbles in it, its a finished industry for decent sparks, its 90% semi skilled work.
Don't know why decent sparks persist trying to compete in the domestic game (maybe the cash jobs) How many domestic vans driving around out there with logo's trying to get work thinking they are proper business's, its laughable.
Better off working on a proper sites doing commercial/industrial work.
Got to disagree with you Anthony, whilst I also disagree with the down grading of Electricians who do mostly Domestic to DIs, in my opinion you are an Electrician, or you should be, what ever work you do.
The Training outfits are doing a disservice to the Trade by inventing DIs, a diluted Electrician, whilst I don't personally like the short cut way to qualification, I understand the situation, there are some very good Sparks coming from this route, and many bad ones.
The domestic route allows people to make a living, many Sparks can't get a foothold into the commercial/Industrial market so Domestic is all they have left, so please don't knock Domestic out of hand, I am a time served Electrician, don't like the short route but understand the dilemma, something I have to live with, we have several short route non Apprentice people on this forum, whom I regard as clever dedicated Electricians, and good luck to them, you do these people a disservice by laughing at them. Rant over:mad::p:Do_O
Supply and demand. How long before the cheapo boys realise they can't make a living at the prices they're charging.
I know this is an old thread, however I found that I have great difficulty in getting a correct price for some jobs.
Builders seem to have their own ideas of prices ..
whilst they add on their percentage for a finders fee for the work.
I recently priced work at £200 for some sockets and lights in a new small extension.this was for a builder
Whilst doing the work, the owner was there, he was asking why I was charging £410 for the job!!!!
so maybe the builders that are driving down the prices are to blame ... needless to say I have made it clear to that builder now my prices are higher or I deal direct with the customer ..
I do like reading these rants.
Where I live we don't have the same problem with non-british under qualified individuals undercutting our prices. But saying that, I still find problems finding jobs.
When I started self employed last year everyone was saying there was a shortage, - everyone's crying out for electricians.... they'll be no trouble getting work. .... Hmm? I must be doing something wrong?
Your average homeowner doesn't understand the work involved - the testing, the paperwork, nevermind paying for overheads.
Your average homeowner still gripes about having to take a car to a main dealer instead of Dodgy Dave round the corner. But it has to be done to honour any warranty.... and the fact you need a computing degree rather than a mechanical qualification these days.
I was asked by someone to quote for a supply to a detached garage at their house. They got my number from a mutual friend who referred me. I asked for their address and we would arrange a visit to see what was needed.
So far I haven't heard back.
My wife thinks they got someone else to do it because I didn't give a price over the phone.
I had to explain to my wife that I can't just pluck numbers out of thin air.
If she thinks that way, then Mrs Average Homeowner may think the same.
Another recent job involved me making up a temporary board with 6 double sockets for a property that had had a burst pipe, so that the cleaning firm could dry it out. I was told my quote was too much, so I brought it down a bit. Still more than what they said their normal Edinburgh contractor quoted. I explained that it still had to be tested, certified and constructed to current regs.
Their normal contractor probably has a stock of temp board already made up that they move from job to job, and charge hundreds for them each time.
I got that job basically because the property is 50ft from my front door.
^^ you win some, you lose some.
It can take 3-5 years to build up a successful SE business........... so don't expect too much, too soon.
Thanks, Murdoch. Good advice.
Last year I was relying on family/friends jobs and word of mouth references, but now I've advertised in the local paper and a bit of sponsorship for the local village summer fair.
Just remember that in the quieter times you can take a bit more time and make sure everything is 110% correct ............. its the word of mouth referrals and repeat business you want ................ plus find a few complementary trades who might need your skills from time to time
AND don't be too reliant on too few customers ............... spread the risk around
For the first 9 months or so most of my work was coming from the print ads I had running. Then I started to get word of mouth referrals coming in (had one or two before this, but they were few and far between). The job I'm doing now came from a referral from someone I did a job for way back just after I started in 2016.
Everything else I would say... @Murdoch 's already said it. It's sound advice for anyone starting out.
re win some lose some, how true is that . I recently spent a lot of time sorting out a lot of things for a friend of the family. Probably about a days free work all in ..they wanted downlights changed over and when I gave them a quote
because it wasn't free time they went elsewhere and paid double what I quoted...
also, they had the cheek to say I was taking advantage of the friendship by charging for my time !!!!!
argggghh
argggghh
What an insult.
Why are people going on about jobs they didn’t notify?
From what I can see, the jobs don’t need to be notified.
Outside light, outside PIR, unless they were not fixed to the exterior of the building, never needed to be notified.
That is awful, DC. Some friend!
Wait until there's another job in their house and they cant get anyone to come out quick, then all will be forgiven
and of course, he'll be too busy to oblige. bloody chancers.
Hi Jim / JK (think it's Jim from a quick search)
I have noticed a major cut in standards from others.
I have 1 local firm who issue EICR's that are not signed and things like SPD being checked are ticked in domestic installs where there are none and nobody bats an eyelid.
The letting agent still uses them
I have used the mybuilder etc. a couple of times 9-10 years ago and binned that.
I DO carry out EICR'S as a loss leader (and do test them to a good standard). I get around 95% of the remedials and that's where I make my money.
I prefer to let the 'bottom feeders' get all the cheap stuff as they are welcome to it.
My rate is £40 for the first hour and £35 per hour afterwards.
I am booked up till the end of April so things are OK.
It is indeed Jim. And like your good self, I too am bald.:D
Me too, I'm afraid. I'm extremely annoyed and concerned about what I've witnessed over the years and am now actively involved in trying to get the Scottish Government do something about it. Thankfully, the ball is now rolling at long last and momentum will now surely increase.
http://www.select.org.uk/selects-campaign-recognition-professional-electricians-raised-holyrood
The sooner those who are incompetent and unqualified are identified and prohibited from working on electrical installations the better.
These underhand practices defeat the purpose of an EICR entirely. I've just started doing EICRs for a Glasgow-based agency who got rid of their previous contractors for this very reason.
The letting agent still uses them.
That's because the agent couldn't care less about the quality of the report. All they're interested in is getting the report done as cheaply as possible and seeing the word 'Satisfactory' at the bottom of page 1.
I've done over 100 jobs that came via My Builder, but have only done one through the site since last September. I got fed-up of being continually undercut by young boys out to make a name for themselves. The average age of these guys must be around 20. It would appear that they come out of school, go to college for 3 years then go straight to My Builder and Rated People. Indeed, every time I log-on there are inevitably more fresh-faced boys using the site, crowding-out an already overcrowded market.
I've had to compete in my own locality in Glasgow with guys traveling from places like Stirling, Dundee and Ayr. Seriously. When EICRs, smoke alarm installations and rewires come up, they all gather like flies round the proverbial turd undercutting one another right, left and centre. When a rewire job appears so too do the "we've done thousands of house rewires in 10 years and we'll do your house in a day" rewiring "specialists". I'm glad that I don't have to rely on My Builder for work.
I won't budge on my prices for EICRs. I have a fixed-price tariff depending on the size and age of the property which is non-negotiable. The customer either accepts my price or I walk.
That's my policy too. The problem though, is that the bottom-feeders also want a slice of the action for the lucrative jobs such as rewires and are active in that sector of the domestic market too.
I'm struggling to get anywhere near those rates at the moment. That's how bad things are up in Glasgow right now. The city is absolutely hoaching with young boys working for pocket-money and they've all but killed the domestic market stone-dead. Thanks to these clowns, some landlords now expect to have an EICR done for £40, two interlinked smoke alarms and one interlinked heat alarm installed for £100, sockets installed for £25, and houses rewired for £1500. These young fools have created unrealistic customer expectations and distorted the market by way of their cut-throat competition. But ultimately, it is their own throats that are being cut because sooner or later their foolishness will catch-up with them and their businesses will suffer accordingly.
I'm pleased to hear that. I think I'll start operating in your neck of the woods. :D
Glasgow
Website
http://www.jkelectricalservices.com
Business Name
JK Electrical
Cut-throat Competition: The Race To The Bottom
Business Related
JK-Electrical,
DC-backfrom the past,
