L
Lexlee
Hi, posting for a friend,
Whilst fitting a LED Light bar ( believed to be 120w) to a Landrover Defender (1995) he tapped into the signal wire of a relay that supplies his roof spot lights and used that as his signal for the light bar relay..
He has used the horns earth for the relay and also connected the earth from the Light bar to the same point, as it's redundant (air horn fitted)
His problem is that the bar initially lit up on main beam, then when to try the flash ... Nothing. The relay for the light bar can be heard clicking on and off, and when the bar is disconnected has correct voltage at the light bar connection point. when the bar is reconnected the voltage drops to 3v at the same point. Thinking the Light bar was now defective he then tested it on another battery and it works fine..
As there's not a great deal there could it be
1 Problem with signal to light bar relay
2 the earth point for relay being same as ligh bar
3 the relay itself
The wire he has used is 17 rated at 17 amp
Hopefully I've explained well enough ... If anymore info is required only to glad to supply it . Friends can be a pain as I hate typing , any ideas on subject would be greatly appreciated.. Thank you
3 the relay itself
