J
Jacob1995
Hey guys just wondering if anyone can help me draw up a circuit diagram for this, would really appreciate the help.
Need to draw a control circuit that consists of:
1. A motor to be started and continue running in forward direction by momentarily pressing push buttom SW1.
2. The same motor to be started and continue running in reverse direction by momentarily pressing push button SW2.
3. Pressing push button SW3 will stop the motor regardless of direction.
4. A thermal overload will also stop the motor regardless of direction.
5. When motor isnt rotating but the circuit is energised, a red led will illuminate.
6. When motor is rotating in forward direction, a white led will illuminate.
7. When motor is rotating in reverse direction, a blue led will illuminate.
8. Only 1 led is to be on at a time.
9. Once running, pressing the other direction push button will not cause the motor to change direction or damage the circuit.
10. Operation of rotary switch SW4 will allow SW1 to be used as a jog push button in forward only.
