G
Gringoking88
Hi all,
Was just looking for some best practices around using plastic mini trunking.
How do you guys join trunking on corners of walls that are not right angles so you can't use the normal pre made bends. I mean I've got a vertical wall and that has got a bend of about 30 degrees in in.
Every time I cut the bloody stuff I end up with a slight gap in the trunking which does not look great tbh. I was thinking of just using caulk or silicone filler but am seeing if there any tricks of the trade?
Many thanks,
M
Hi all,
Many thanks,
M
Get one of these
years of practice would help.
Reactions: MDJ
I use a small mitre saw and angle guide, along the lines of the one in image below but about half that size, it was designed for picture frame making, for angles i use a measuring device. its all about the angles!! i am a bit of a maths geek so enjoy all the planning and prep before hand :)
Im changing my socket ,so red goes in L black in N , but why new socket has 2x holes for green ?
Does it matter which hole they go? Left or
Right side ?
now do we have to point it out to you .
I don't cut through the back of the trunking in that situation. Just one cut each side then bend and mark than cut out resultant wedge shape and cut lid to suit. I use side cutters or junior hacksaw.
:eek:
Stuff some fire cement in any gaps.
  • Creative
Reactions: freddo
I use a coarse file to adjust the cuts until they perfectly fit. Though to be honest I hate mini trunking, it's all about steel conduit at the moment, seem to be fitting loads of it.
Hi all,
Many thanks,
M
Good question Gringo! I was thinking about this the other day and didn't come up with any easy answers. Gavin's suggestions seem good as do Freddo's. Somebody needs to invent a moveable or bendable corner piece! Saying that, I wonder if you just made some straight cuts on one of the corner pieces you could bend into shape? My sunday now has purpose :)
I have an angle measuring tool and like @Gavin John Hyde I'm a bit of a maths geek so I generally measure it, draw a little diagram and work out the angles, then mark up and cut.
Doing the final fit with a file like @freddo
As above. Then hide the lash up with some appropriate coloured silicone/caulk :)
Angle gauge, steel rule, saw, file, knife. Apply tools to trunking in the manner prescribed by the art and craft, and a perfect joint results. There's no magic shortcut - electrical installation work is a craft and it requires skill and practice. A joiner can make joints in wood of arbitrary angles that fit together exactly and look smart; an electrician should be able to do the same with electrical materials. Unfotunately, the very kind of work that uses PVC mini trunking is not the kind to draw the attention of the most skilled craftsmen, so one doesn't see precision work in mini around the place.
Wind back the clock 100 years and you would see electricians making complex joints in wooden casing with flyovers, double mitres etc. That wasn't something you could learn from a book, and was nigh impossible for the DIYer. When I look back at my first few years' steel trunking work it's got some rough edges (not literally!). It has taken 20 years to get good at it and now I don't do much on the tools and avoid first fix like the plague, I'm losing it again for want of practice.
If it's any consolation, when my mentor asked me to tube up an area in 20mm BE steel con while he was in hospital, with funny angles in roof trusses, he made sure there was just enough tube. I made so many misbends that I secretly bought another bundle of conduit and cut up and took away most of the errors!
You need the right mini trunking for a start.
Marshall Tufflex or similar with a lid that overlaps by several mm is useless for making neat mitres. The best trunking by far for forming angles is CEF Centaur because the lid is completely flat and fits securely.
I can form perfect angles and double sets with Centaur, no chance at all with Marshall Tufflex. All it takes is a little thought and practice.
Caulk or silicon to cover poor workmanship is inexcusable. We are supposed to be professionals.
Of course you could always do it without the trunking, save a bit of time and money. Nothing beats a bit of clipped direct.
  • Funny
Reactions: SparkyChick
Thats very eco of you - Recycling photographs from another forum thread. Although the first pic there is diabolical for mini trunking.
  • Funny
Reactions: 2 people
I had someone helping doing the trunking and I said would you like to use my lucky side cutters or have the misfortune of receiving a steel toe cap in the groin for fecking about.
  • Funny
Reactions: EalingBadger
  • Funny
i get a piece of scrap (cut off) trunking lid. cut a nick in the sides, bend to the angle of the wall/ceiling/whatever, then transfer to whatever i need to cut.
How do you guys do angles in trunking
Gringoking88,
Squid,
