Nov 18, 2017
124
95
103
63
Essex
Hi all,
As the title suggest, I have today replaced an old (1977) Wylex fuse board for a nice shiney 10 way consumer unit. However, when I took the old fuse board off the existing cables gave no slack, not even a smidge. They were solid and with just 200mm of cable left hanging out of the wall.
This was obviously not enough so I had to extend them to reach the new terminals in the new box. I have surprisingly not had this scenario for a very long time, so my dilemma now began. Do I use wago's, choc boxes or butt crimps? I opted for the crimps but also added heat shrinks to them as I did many years back when doing this. Probably a mistake, but I felt more comfortable with this despite the reliability of wago's.
Would you guys please let me know what you would have done given this scenario? A rewire was not an option before any comedians suggest it. ;)
Everything tested OK by the way. I'm just concerned about the longevity of crimps compared with wago's and choc boxes. They all come loose over time.
pic would be nice . go on give us a laugh.
  • Funny
Reactions: Martyn Fletcher
Never liked choc boxes or crimping solid wires, so probably wagos up to 2.5 and uninsulated crimp with heat shrink for the bigger stranded conductors.
I had to extend a cooker circuit on my last CU change, used wagos for the 6mm twin and earth. the 3 pole red ones are good for upto 6mm and 40 or 41 amps. for the smaller sizes I tend to use the orange ideal inline connectors. not had a problem with them yet.
Wagos can fit 6mm now
  • Informative
Having used good old junction boxes for so many years, I still look on all those pretty plastic things with some misgivings, although I do use Wagos and such in preference.
  • Informative
Buzz can’t be putting smokes into the CU. Would be a fire risk with all the loose connections.
Use wagos,crimps or blocks. What ever you think is best for that situation.
A pic on my nice new CU or the old Wylex thing that is now gone and of which I took no pictures?
I always take pic before and after has security . before I go to prison .
  • Funny
Arent those red ones just push in? You can't re-use them so they seem to be more permanent. I should perhaps read up more on them.
every time I go to some jobs ,I think to my self how do I solve this puzzle . .thinking to my self shall I ring a friend, no . I just get on with it .
...and if you were of a specific,religious persuasion,you'd have all those virgins to look forward to...;)
I use the spliceline connectors for all 1.0-2.5 cables and will be using the new larger wagos for 4&6mm instead of yellow crimps.
Essex
Consumer unit upgrade with no slack on existing cables
Martyn Fletcher,
brianmoooore,
