Discuss rubber gloves in the Australia area at ElectriciansForums.net
M
mayfair
Evening all
got to do a job tomorrow connecting the meter tails from a 3 phase system to a new DB cannot in anyway kill the supply, anybody used these 1000 v rubber glove jobies ? i always work dead but just cannot get supply cut off HELP please
Is there no way of pulling a fuse? Really don't recommend working live with tails..... full PPE is going to be a must.
Hi m8 the meter room with fuses is in another building next door to the one im working in..... there0s the prob its been sealed off due to none payment of bills, police padlocks the lot so no hope lets hope i dont pop a phase
Not good enuff reason to work live IMO.. Only ever work live if lives depend on the supply.
Yea really man is there any way you can get in touch with police or whoever padlocked the room.... if the room that was locked is connected to other supplies and the isolation of those supples, then legally I'm not sure the coppers should have locked it.
your talking Spain here M8 no trunchens just big shooters rather take my chance with the rubber gloves lol:D
I am confused here? Doesn't the ewr act state that you must never work live? but as someone already mentioned what if there are lives a risk i.e in a hospital?
Ha oh well that changes everything! I'd go full legnth 1000V gauntlets, apron and visor - the works. When disconnecting, unscrew terminations fully to ensure a quick and smooth disconnection. Hold cabling near to the termination to stop it flailing about everywhere when you pull it out. Once removed, get your tape and starting from the existing insulation, tape the bejeezuz out of it for while you're working - remember to leave a good end so the tape can be removed easily. DO NOT rely on the rubber gloves.
EDIT: just seen those ends P'Wise posted. Use them and forget about the tape.
so gloves not up to much then
Not really..... how many times have you had a belt? And how many times has that been from a wayward elbow or forearm, or forehead for that matter. In reality, if everything goes absolutely tickety-boo, then you wouldn't even need gloves - just pull the cable, isolate it and get on with your day. But how mant times does everything go completely tickety-boo?
If you've got someone to send them from the UK, RS have them slightly cheaper.
Welcome to rswww.com
Your guess is as good as mine as to how effective they are but I'm sure with a VDE mark and the companies reputation that will suffice, let us know how you get on if you use them :D
will buy gloves and give them a go hope im still around to report back. All joking aside any juniors out there i would normally not consider this and have not done so for last 30 years in business
EWAR dont realy apply in Spain IMO Id try the police get access and fit an Isolator your side of the wall then let them Lock it back up Common Sence
This is how I would do the work,its not advice
When working live,it was ingrained into myself to work with one hand in the pocket as much as possible
Stand on a rubber mat by all means,I would string a bit of single cable from one corner to the next of that chamber,not a physical,but a phsycological barrier in case of a momentary lack of concentration
I would work in a deliberate fasion and not be hurried in any way
Fear is your best tool followed by respect
good luck and I'm sure real world procedure that sometimes have to be undertaken,they will be overcome
Reply to rubber gloves in the Australia area at ElectriciansForums.net
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
