Discuss Quick! Call a plumber in Chicago in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Doomed
i hate the cold. last nite, wanted to go for lottery ticket.deadline is 7.30. got in van 7.15. by time i'd de-iced windscreen, inside and out, got to local shop.... 7.32. DOH. worse is can't leave beer inn garage, it 's then only fit for australians, got super glue frozen solid. roll on global warming.
Hi Tel, why don’t you do the lottery on the same device that you post with on here? You can then get the exciting emails telling you that they have news about your ticket and informing you that you’ve won £2.80. PS I’m current working on an app that supplies and pours a pint. I’m some way off but will let you know when it’s up and running. :D
i'll consider the problem once i've got the cork out of my breakfast.
Reply to Quick! Call a plumber in Chicago in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
Hi My Triton electric shower which is around 7 years old is gushing water from the bottom of the unit, should I call an electrician or a plumber...
Hi all, just wanted to introduce myself. Old git who likes to have a go and then when I've mucked it up, call the pros in (if I can afford it!)...
Good evening Sparks and Sparkles, Has anyone got a wiring diagram for a storage combi boiler using a Hive (plumber says 1 channel...)... The...
Hi all - just a quick post to say thanks for this excellent resource and to ask a quick question! PV Panels and battery storage - is there any...
