Discuss rcd 's in the Australia area at ElectriciansForums.net
Just to elaborate for the OP they can have different max current ratings eg 63A or 80A and they can have different trip ratings eg 30mA, 100mA and 300mA and some can be time delayed - depends what the installation requires:)
Depending how and what is backing up the garage board ie: where it is fed from and what over current device is backing it up? will depend on what you use in the garage board as a main switch.
Can any rcd be used for a main switch as they are DP for example to a second consumer in a garage.
cheers
Reply to rcd 's in the Australia area at ElectriciansForums.net
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Given the RCD pictured below With the manufacturers instructions here: Am i right in interpreting that as well as being able to bring the...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
