Discuss inverter to run a robinair recycling machine 34134z in the UK Electrical Forum area at ElectriciansForums.net
look on the rating plate of the machine for its power rating in Watts (w) or (va)
take that figure and multiply by 3 and you will have a suitable sized inverter.
to be safe, if there are any delicate electronics in this machine, a pure sinewave inverter would be my recommended option.
i.e. if the rating is 450w then an inverter over 1350w should be suitable
Thank you so much for that info, will I be able to run the machine for an hour, should I have an extra battery hooked up?
I wouldn't run it from your vehicle battery as it will probably drain it quite quickly. You might get away with a leisure battery connected up to a dual charging system.
What is the current draw of the machine? How many times a day will you be using it? Is a portable generator an option?
Run time depends on the power rating of the machine, not the inverter.
Until we know the power usage, we can’t estimate run time on battery charge.
Reply to inverter to run a robinair recycling machine 34134z in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I would like to put a washing machine in a cabinet in the bathroom, and run it's power cord through the wall that separates the...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
I have a 110 5kva transformer. Run it off a 30 meter exstension lead running from the house into the Work shop. The transformer works and powers...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
