Discuss 16mm tails insulation in the UK Electrical Forum area at ElectriciansForums.net
16mm meter tail cable has a double layer of insulation. What do all think of removing the outer layer of insulation, to make it flexible, when the cable is being run entirely in plastic trunking.
It must be a tight spot if your having trouble with 16mm. When I get to use 16mm tails rather than 25mm its like a holiday.
I would just buy tri-rated singles in run in containment, saves damaging the insulation when stripping the outer sheath off
Technically I don’t think there’s anything wrong with it.
Would I do it, is a different story.
As others have said, get the tails with more strands, much more flexible.
It is 3 inch trunking. Not that tight. As it is inside trunking making it more flexible occurred to me. The trunking adds insuation value. Why do things the hard way? But as been mentioned, it may not make that much difference as the copper may be the stiffness.
I think true “singles” have a tougher insulation for drawing through conduit and the like, so stripping off the outer grey sheath and leaving the inner insulation wouldn’t offer the same protection.
It would be placed in, not dragged through, so the insulation would not be harmed. Only 1 to 1.5m long.
love using 16mm tails , one day i will start a campaign to ban 25mm tails and make 16mm tails the law
Reply to 16mm tails insulation in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a domestic installation to rewire and the main incoming fuse is 80 amp so i am using 16mm double insulated tails, is the main earth size...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
