Discuss PVC surface boxes in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I am wondering if any sparks out there know of a brand of 32mm deep PVC surface boxes with multiple knockouts for MT2 & MT3 ( 25mm x 16mm & 38mm x 16mm) mini trunking. Marshall Tufflex MSSB35 & 36 WH were perfect but are now discontinued, and their replacements MSSB91 & 92WH only have a single knockout and a single 20mm conduit knockout. Asked my local wholesalers without any success, any help would be appreciated, it’ time consuming and not practical having to drill and file out apertures!
Gratefully Griffey
MSSB35WH, MSSB36WH & MSSB20WH seem to be available from a few online suppliers - CEF show 133 of the former in stock and electricpoint are reasonable on price. Might be worth stocking up if you can't find a suitable replacement.
Gratefully Griffey
Cef still have plenty of them here as they keep giving to me and I hate them so end up handing them back
Griffey
I have a 45mm deep white marshell tufflex surface box with the multiple trunking knockouts and 3 MT2 trunking adaptors that you can have for the cost of the postage if you want them ?
Reply to PVC surface boxes in the Electrical Tools and Products area at ElectriciansForums.net
Hi does anybody know of single / double PVC back boxes that have multiple 20mm knockouts like metal clad? Or are plain with no knockouts ? The...
Hi Guys, I have to fit an MK 3 way grid surface mount box below 3" metal trunking and require the use of all three knockouts on the top of the MK...
Background I'm running some low voltage cable (e.g. CAT6A data cable; coax cable; HDMI cable and speaker cable) to a number of rooms of the house...
6K
does anybody if you can buy a 32mm pvc box with 20mm knockouts on the the side the ones that you fit 20mm conduit into.
Deleted member 26818
O
OK. Ideally I need some 2G white surface boxes in PVC with 20mm knockouts on both sides ....... Centaur do some with a 20mm knock out on 1 side...
5K
