Discuss Wiring advice for access control in the DIY Electrical Advice area at ElectriciansForums.net
Corcor12
183242EE-780A-4098-A258-72FF912B06CE.pngCan anyone recommend the correct wiring for this example - it’s an access control standalone system - company recommended CAT5 cable is this accurate.
I assume I can just use separate positive and negative cables
View attachment 91436Can anyone recommend the correct wiring for this example - it’s an access control standalone system - company recommended CAT5 cable is this accurate.
Was thinking if it would work to use alarm cable to extend red and black however what colours are suitable for purple and green as these are not in the alarm cable wiring
To be honest, you don’t really need to follow the cable colours that closely.
It is advisable to use red and black as +ve and -ve, but the others…. not as important.
As long as you know what goes where.
You could write on the wiring diagram you’re using whatever colours the wires are in reality.
CAT5 cable is 8 core, so there will be spares.
I would use alarm cable for the setup in the OP
With systems like Paxton I use a mix of Cat 5 for the network devices and readers and alarm cable for the locks or locking devices
Reply to Wiring advice for access control in the DIY Electrical Advice area at ElectriciansForums.net
Hi - we have an inline heater for a vent system that appears to always be on. I believe the electrician may have wired it incorrectly with only a...
I hope this is the correct thread. I have to replace the main oven selector switch in a Smeg A4-5 cooker. I can't find a proper service manual...
Hi, The wire of my dehumdifier is broken (Meaco 20L Low Energy). The wire was being pulled over a period of time, which seems to have lead to a...
I need to handle power failure for my electric strikes in my house. Of course, I can leave the keyed entry on the knobs, but what if I wanted to...
Hi Everyone, hoping someone will be able to help me decipher the wiring for this hoist controller. the handset it came with has stopped working...
