May 27, 2022
42
London
Trainee Electrician
A client asked me to add two sockets in their bedroom
I took power from two sockets in the lounge which is behind the bedroom wall.
I ran a cable out of each socket for the new socket
The problem is it now is tripping the RCD and blowing the old Existing sockets and light switches
But the new sockets I added still work fine
The old existing sockets and switche are blown and unusable
When I try to reset the RCD It pops and Sparks down
Any idea to why this is happending
if the old sockets were on a ring, and one leg has popped out... the new sockets, being connected will still work, but theres maybe another floating live touching the metal back box.
can you take photos of the back of the sockets? there might be something obvious to us that you havent seen
Reactions: pc1966
The thing is the client phone back saying there’s no power and the RCD is popping down and sparking so I went back same night, and opened up the sockets I touched the connections were fine the socket sparked and popped while the socket was open so no loose lives
Sockets "blown"?!! What does that mean?!
What are your IR results for that circuit?
  • Optimistic
The actual sockets I took power from sparked an blew
The wind blows. You mean the mcb tripped off? If that happened there's no way the new sockets could be still live
no the actual sockets sparked and blew in front of me
The mcb never tripped once only the RCD
I still dont know what you mean. But anyway, if the RCD tripped the other sockets def were not still live. Did you do any testing?
No tests on the ring were carried out
So how do you expect to find the problem without testing? Apologies if I’ve got the wrong end of the stick here, but if I’m dealing with a symptom of tripping pretty much the very first thing I do is IR testing
No testing
On the assumption you're trained and experienced, what does that tell you ?
so I went back same night, and opened up the sockets I touched, the connections were fine, the socket sparked and popped while the socket was open so no loose lives
Did you leave the socket sparking and popping when you left or have you isolated it / them?
Well with all due respect you'll be hard pushed to get much help with that admittance, not good.
Going back to your original question, "any idea as to why this is happening " I'd suggest it is because you are vastly underqualified/experienced to be carrying out this work. The fact you called the customer a client suggests you are being employed to carry out this work which you probably shouldn't be doing and are probably at risk of endangering property and life.
From your profile I see you are a trainee so is this a private job?
Yes they were isolated the socket was removed completely and connections put into a choc box
Are you doing this as a private job?
don't have much experience with fault-finding so that's why I'm asking that question. I've been doing electrics for 2 and a half years
London
Trainee Electrician
Blowing sockets and popping RCD
Josh555,
timhoward,
