- Aug 12, 2017
- 14,324
- 20,718
- 3,557,381
- 51
- United Kingdom
Not had much experience with earth rods in the past 30 odd years, so I’m asking here before going home and reading a book.
Was asked to look at an older style ev charger (bp charge master) and after a recent visit to another job with the same problem, I thought I’d check the Zs first at the charger. Came in at 190 ohms. Without knowing the earth system at the time, I then checked same at the board, and a random socket in the kitchen…. Both around 190 mark.
Asked where the meter was, and got a surprise when they directed me halfway down the garden to a meter box on the wall, at the bottom of an overhead line pole.
Also checked Ze there off the service isolator and rod, and still got 180 ish ohms.
Like I say, zero experience I’ve the last 30 years. This is the first domestic TT I’ve ever come across in Scotland.
Apologies for pic, I might edit it later to turn it around.
I believe the max Ze for TT could be as high as 200 ohms… (correct me if google is being wrong) so those 190 readings are ok…. But maybe not for the ev charger?
Is this suppliers responsibility to give a better earth, or will I need to drop another rod?
