baldelectrician
Mentor
1,076
1,653
10,239,798
Ayrshire, Scotland
www.baldelectrician.com
Business Name
abc Electrical
Was on a job this week and found a novel way of joining 2 armours and buirying them
Was at a unit one of my customers are taking over lease on, more stuff like this but this was the only thing worth photographing
Like a bit of quality work
Reactions: 3 people
Now that's nice!
I like the way they have used the earth connection literally, just bury it in the earth!
And this worked without problems?
Yes, the Zdb was 640 ohms- no RCD - all A OK !
You would have thought that they would have at least wrapped it in a carrier bag :confused5:
Yes the famous IP68 carrier bag, works wonderfully in so many cases!
Reactions: 4 people
Your average bag is only IP44, so normally you need to double bag.
Did balde unearth that joint as in the pic?
It was inside a bit of plastic 1.5 inch pipe
The way the connectors are staggered means it was most likely an 'electrician' that did it, not a DIY'er. :(
When are you guys going to let Tony back in the Arms?
He is after all one of the superior members of this forum!
sweet.... i like teh fact they never used electricians tape to hold it together...!
Every one knows you are not allowed to use tape nowadays, got to do it properly!
So if you use 2 IP44 bags does it really = IP88
This is acceptable but to meet new EU reg's one bag has to be black and one yellow so to act as a warning if accidently unearthed, and also the joint isnt allowed within 300mm of a fish pond... just reading your posts and cant believe no-one mentioned these important points.
So Morrisons or Asda bags are not going to cut the mustard then despite their superior IP rating. Dammit I'll now have to spend tomorrow digging out that flex joint I buried last week. I did tape it up with masking tape mind you so it'll probably be ok I guess.
baldelectrician
Mentor
Ayrshire, Scotland
Website
https://www.baldelectrician.com
Business Name
abc Electrical
New method of jointing cables underground?
Electrician Talk
baldelectrician,
Knobhead,
