might not be the sparks' fault. wet-head may have been after.
Very true, I should have said the tradesman responsible should come back to sort it out. Insulation is a viable option but why bodge someone else's work to make things right?
If your worried about cables becomeing slack and eventualy resting ontop of hot pipes put a wooden noggin inbetween the cables and pipes the full width of the gap between the joists....that way the cables will sit ontop of it,could even clip the cables to the noggin.
yer canna beat a decent noggin. mine's hobgoblin tonite.
Reactions: 2 people
Maybe he should put a dwang in instead of a noggin? :wink_smile:
Does it look as good as this?
And who came first. Sparky or electrician:omg_smile:
I've seen far worse than that. Few years ago, rewired my grandmas house and found the T&E in the same holes as the copper hot water pipes, actually touching and in places wrapped around them. Surprisingly, I didn't find any issues with the old cables before I relocated and replaced them.
The main issue with the picture is the integrity of the the joist itself.
Oh poo.
Meant sparky or plumber. That'll teach me to try and be a smartrse.
Reactions: 2 people
Wire and hot pipes
Tags Tags
pipes wire
tedglen2,
Geordie Spark,
