Discuss Neutrals in light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dazza
I was wondering what folks do with their neutrals when three plating at switch? I've been using wagos, but I was chatting to another sparks and he was saying that he had been pulled up for not securing the neutral in the box. What are people's thoughts?
nothing in BS7671 against wagos or choc blocks. bet there's something against in the niceic rules though.
This was a grey area many years ago, from memory my old college tutors and sparkies, said never have neutrals in back of switch box, have done it myself a few times.If I did a job and it got knocked back I would fit a 20amp dp switch.:D
Nothing against a neutral in the switch back box, but only as and when it's required. Looping a complete circuit through switch boxes is another matter altogether!
images
Just for you 7029Dave. I'm sure you can figure them out mate.
push in for solid or stranded cables e.g. 1.5mm, 2.5mm. lever type for flexes. just bear in mind that they're not like choc blocks where you fit L,N, and E in. they're called 2 pole, 3 pole etc., but should be called 2 port etc.
Presumably you also have nothing against looping a perm live through a 3 plate light as long as it's required......oh,it isn't though is it?....:D
if assesor wants to be pain then get some self adhesive cable tie mounts (toolstation stocks it),
fix them into boxes using a screw each and hold the wires with a cable tie.
Before sliced bread what was the best thing?
Beer? Cheese?
I would say those two are much better than sliced bread, in fact sliced bread is pretty rubbish in comparison.
I think 'the best thing since sliced bread' relates to 'the best thing in recent times' rather than 'the best thing ever', otherwise people would compare things to 'the best thing since beer'.
But the assessor asked for the neutrals to be fixed to back box. Wago won't achieve this!
In accordance with which reg?
The lives aren't fixed to the backbox either, the terminals in the switch are fixed to the switchplate, not the backbox. Until you screw the plate back they're in a similar predicament to neutrals in a bit of terminal block or a wago.
The reason cpcs are terminated in the backbox is to earth the backbox, not because they need to be secured; if I were terminating cpcs in a plastic backbox with a plastic switchplate I'd have no problem terminating those in a bit of connector block or wago as well.
As mentioned, I couldn't think of a reg that prohibited a neutral in a switch box. The point made about fixing to cable tie base is a valid one at least the neutrals are attached to a fixed point. As also mentioned I think the schemes like to think up these things so they can at least pick us up on something in our assessments!
got it in one! BS7671 rewritten by scam providers.
To make the thread more interesting----------------I always wire feed and neutrals to the switches and only have switch wires and neutrals at lights, I wago the connections in the switch boxes and also always use a minimum 10 amp rated switch in domestic situations, pick the bones out of that :smilielol5:
Maybe the assessor should be asked where in BS7671 it says what he/she is asking. How can they pick you up on what is just their personal opinion?
Ironic that there are thousands of so called qualified spakies out there doing poor work and all this assessor seems to be fussed about is something that is neither against BS7671 nor IMHO of any concern if in a suitable connector etc.... looks like they are trying to justify the extortionate charges the command.
Reply to Neutrals in light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a rocker type light switch the sticks out bit too far and interferes with a drawer, as in the picture. The switch seems properly installed...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
