richy3333
Mentor
2,879
10,456,798
Far North Scotland
Just bought a house and the previous owner left a present for Eng 54. Sorry it's not wrapped :(
Reactions: 5 people
Knowing the PO it will be a £100 as a non standard sized object!
No No boys, depth is key. If you get it started at the right angle Richie and just keep whacking and extending - it should easily get to Cyprus by Christmas, and ... err ... it might be stable?
Reactions: 3 people
Thanks,
Actually i could make use of that twigg, i can cut it in half and use as test spikes for my Earth tester...
I wouldn't expect much of your earthing system if that's what's been used mind, get it PME'd is my best advise!! lol!!
Reactions: 3 people
No problem you can cut them in half and they should fit, 3 foot is overkill anyway when a 1.5 foot rod is more than adequate with an upfront RCD ;)
Bet you wished that was all you needed when you need to install a TT system in your part of SA!! lol!!
Reactions: 2 people
Hi,
Don't even bother knocking it in, a bit of damp sand around it and the jobs a goodun.
Regards.
I'll 'ave it if E' cant make use of it.......use 'em all the time...:shades_smile:
Thanks,
There's no TNCS in the area and getting a TNS isn't straight forward, but we'll see :)
Next you'll be showing a picture of a drill with a 3/8ths chuck.... Used to know a bloke that went mental when he saw one, would start shouting out loud "3 eighths chuck? 3 eighths? You need 1/2 inch chuck mate"
You do not want to use any of that copper coated steel rubbish you need a proper star shaped copper earth rod like this:
I have my BS951 clamp ready fitted and a high quality earth rod box, I am sure that 200 ohms is only a guide and the 485 ohms I got on installation will be fine!
I put it close to the wall so that it is not exposed to the weather.
What more could one do?
I am sure E54 will be pleased!
Reactions: 7 people
Boolox I use an SDS now :)
And i'd expect nothing different from you!! lol!!
richy3333
Mentor
Far North Scotland
Merry Christmas Eng 54 - a present for you ;)
richy3333,
Engineer54,
