Discuss Wylex MCB's in the UK Electrical Forum area at ElectriciansForums.net
L
lufcboy
Hello - I have a Wylex NS11 consumer unit and need to install a 16amp C breaker. I have spoken to several Electricians who say that the consumer unit that I have is a relic of the 80's (Although my flat was built mid 90's).
The question is, does anyone know where I can obtain the breaker that I require.
With thanks
David
OK I have tracked down some breakers - does anyone know for certain if NH and NS range are compatible they look similar and I found a fact sheet entitled NS/NH breakers.
Again with thanks
Ask a wholesaler to ask wylex, it isn't difficult is it?
Thanks for that and no not difficult but you are. e-mailed Wylex myself and all they would tell me was that "The NS range is obselete" despite me asking the question in the e-mail
Reply to Wylex MCB's in the UK Electrical Forum area at ElectriciansForums.net
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
I am doing a campervan conversion and have a 16A/250V shore power connection coming into a consumer unit which has two breakers - one for the AC...
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
