Discuss Proving a point - for real in the UK Electrical Forum area at ElectriciansForums.net
pc1966
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and proving unit - and my tester failed.
Yes, one LED lit, but no sound nor any of the voltage indicator LEDs functioning. So bin for that tester now. Thankfully I also had a simpler TIS one in the car so that got used instead, but it is a useful warning that even a modern tester, lightly used and in physically good condition, can randomly fail! Not good when your life depends upon it, and a reason why you should always prove your tester is working..
Reply to Proving a point - for real in the UK Electrical Forum area at ElectriciansForums.net
A builder friend calls me up to have a look at a "strange situation". He points at a joint box above and outside a back door. "Old outside light?"...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
I'm trying to replace 4 inset downlights with surface mounted ones: Phoebe LED, Atlanta Universal Downlight 6.5W/3000K, chosen as they'll...
Hi. We have a circuit where some of the sockets have a dangerously high earth loop impedance. This was identified by a professional electrician. I...
4K
