Discuss Do we have to fit AFDD's in domestic installations? in the UK Electrical Forum area at ElectriciansForums.net
They better hope its under 18m !! Otherwise its 5x new AFD and thats not cheap !
As @davesparks pointed out the guidance (BPG #4 page 20) codes this as C3 so not essential to change.
If they need a new CU for other reasons then you should be fitting AFDD due to the current regs requiring them, but not as an EICR-forced change.
I've only watched the first of the videos, not a good showing to not detect some serious arcing.
I've seen the result of parallel arcing at church. We had a fuse blowing intermittently but couldn't find any cause. It was only when someone mentioned a socjet not working that I found a length of T&E going through a 3ft thick wall where the mice had been at it - and about 6" was burned away from arcing, just like the test the video showed the Hager device not detecting.
Reply to Do we have to fit AFDD's in domestic installations? in the UK Electrical Forum area at ElectriciansForums.net
Recently been working on a system design for a LL. I was told the building would be a three floor 16 room HMO, so the design was done to the...
5K
Haven't been on here for a while, so sorry if this has been discussed before. BS7671 2018 + A2 Regulation 421.1.7 recommends AFDDs for...
9K
  • Locked
5K
Hello all. I'm just looking for a bit of advice regarding our meter. EDF keep badgering us to have a smart meter fitted, and they recently...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
