Discuss 1amp Fuse in the Auto Electrician Forum area at ElectriciansForums.net
Status
Not open for further replies.
Car radiator fan? I doubt it very much! Do you have a multimeter or ammeter?
I've replied to your other thread.
Depending on engine size and fan requirement - in the region of 10 to 30 amps. Maybe more.
Reactions: DPG
Duplicate/similar thread now closed.
Reactions: DPG
Thinking about it, most multimeters don't measure above 10A, so the OP would need to make sure his meter is up to the job.
Status
Reply to 1amp Fuse in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Long standing issue on my VW Transporter T4. First noticed under 'lockdown'. Battery drains flat if stood more that 3 - 4 days. Industrial spark's...
Hi, I rarely (once a week or once in two weeks) use my vehicle and the car battery goes low, not enough to start. If I connect a 1Amp 12Volt...
Just wanted to get some thoughts from other electricians who regularly do EICRS, does anyone else code a fan isolater with no 3A fuse protection?
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
