Discuss 3 phase board converted to single phase in the Australia area at ElectriciansForums.net
C
chloebear
Hi all,
Just after some advice really - came accross a Crabtree Polestar board today -3 phase 36way board with probably 32 breakers installed in a fair sized commercial building that I was asked to do some elecrical additions to. from the outside of the board it looks fine as all the circuits look to be evenly spread - however on opening the board I find that the board has been "ADAPTED" to work as a single phase board with all the buzz bars linked to the 1st phase.
What is the opinion on this kind of installation - fully populated 36way 3 phase board running on a single phase adaption????????????
They have taken the supply cable (3 core 25mm SWA) to the DB back to the main board at the intake which has more than enough 3 phase - just cant understand why they would not have run a 4 core instead of a 3 core cable (even if they ran a seperate earth cable with it) and supplied a 3 phase into the board
Reply to 3 phase board converted to single phase in the Australia area at ElectriciansForums.net
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Hi, searched the forum but cant locate anything similar so apologies if ive missed something. Ive got a new hob to install in the kitchen...
Hi Looking at a job currently adding a 3 phase solar installation but the distribution board is full obviously a new board is the best option but...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
