A
ash_s3
I need to connect a new cylinder stat to a 3 port valve.
I have on the cylinderstat C, 1 and 2.
On the 3 port I have brown blue and white wires but these are not labeled or identified and there's no instructions to refer to.
How do I know I've connected the stat to the valve correctly as there's no indication on the actual valve which port is open or closed when the motor operates.
The valve operates when I adjust the stat (opens and closes) but I don't know if it's working the right way around!
Cheers
Cheers
