150kWp of SunPower panels made commercial sense?
I'm very surprised at that.
You can argue that with the money men, they made the final decision between the data for the SunPower panels and panels made by Samsung and BP Solar. Their calculations told them that the SunPower units, for our location mind, will provide between 15% and 20% more electricity and thus revenue over the expected 15 year lifespan they have given the building. I'll accept that some of the cost/benefits could be connected to the discount received for the bulk buy as I know there were significant differences between the final three on that, but I do not deal with the money aspect of the Jobs...I leave that to the Guys who have no life.
point of order here, sunpower panels aren't hybrid panels, they're just very high efficiency N-Type mono-crystalline panels.
As such, while they are more efficient than other N-Type mono-crtystaline modules, there will be minimal difference in low light, high temperature or lifetime performance per Wp than other high quality N-Type modules such as those from Yingli Panda, LG Neon, Romag, etc.
And high quality polycrystaline panels will have better medium to low light performance than any of them on a per Wp basis, though the high temperature performance of the N-Type mono's will be better.
So IMO the money men have been misled as they don't understand the technologies involved and just went on the sales blurb, plus they were only given options of 2 x old style panels or latest generation sunpower, rather than equivalent but cheaper panels.
Panasonics HIT panels on the other hand are hybrid panels, and have a -0.29% per deg temp coefficient vs -0.38% for the sunpower, as well as I'd expect, higher low light outputs, though as someone on here pointed out, in the UK that's actually offset by the temp coefficient working against them in cold UK weather.
When did you install the BP solar panels?
Thanks, I was just remembering that BP pulled out of solar about 18 months ago, that was all.
You can argue with the manufacturers and the scientists who provide the data that we used to calculate the most efficient then, because we have to go by what information they give us as we do not manufacture them. Incidentally I did not say the SunPower where Hybrid panels, I said they were HP (high performance) panels. If that gave the incorrect impression I apologise as that was not the intent.
ok you didn't, but you did start off by talking about hybrid panels, then effectively gave the sunpower system as your example having switched mid discussion from talking about hybrid to HP panels.
I've no need to argue with the scientists, as I've already stated I've had this discussion with panasonic's main technical guy and he agreed with me, I'm arguing with you because you're the one who made the statement. You can track everything I've said back to the manufacturers own data if you wanted to.
What you appear to be doing is regurgitating the marketing spiel coming from sunpower without critically analysing it to see in what circumstances and to what extent it actually applies.
Not that I'm saying Sunpower panels aren't very high performing panels, as they obviously are, I'm just questioning the economic rationale you're using to justify recommending them on a big installation such as this... though obviously that rationale may be different if you have been given a significant volume discount for the panels.
Reactions: 1 person
Gavin, I'm in work now doing some night cover, looked up a lot of our costings etc...the price we paid for the SunPower panels, due to volume and using the same supplier for the Inverters etc meant that we paid the same price as we would have for the BP Solar branded and I found in the quote that originally they did a spec using REC panels, but they were rejected as the original spec called for a minimum of 16% efficiency from the panels.
I have looked through the proposals and the data and found that the savings are partly down to the way we are using the panels and the fact that the amount being fed back into the grid will be a minimum of 60kW, in fact looking at the BMS, in the last week we have averaged some 10,801.2 kW/hr back into the grid..
Now I appreciate that a domestic user is never going to be able to compete with that level of generation unless they have a substantial home to mount the number of panels on we have, and it would need to be something like a small stately home too...and clearly a domestic user is not going to be able to negotiate the kind of discount our client's buyers did. Apparently we paid (well our client) £278.34+vat for each of the SunPower panels
With regards my comments about the Sunpower and hybrid panels giving the incorrect impression, please accept my apologies, not the intention at all.
We get that kind of nonsense spec'd all the time. I doubt very much that the guy doing the spec had any idea what that actually means.
I was thinking the same here, 16% efficiency is for a given area of the panel, so if installation space is not a problem, then you use a decent less efficient panel which would take up more space to produce the same power and then your financial numbers would stack up better.
Reactions: 1 person
QUOTE]
I'm a bit puzzled by this, as how can you have used the "same supplier as the inverters", unless Sunpower have started selling inverters? The price you mentioned for Sunpower is about right, (although prices are best kept private IMO) but if your company is paying that same price for a Chinese panel like BP (called Sunoasis now I think?) then you are not buying well. If the return calculations have been presented with both modules costing the same then your customer has been given inaccurate information from which to base their decision.
Funnily enough that conversation was had in the office originally, but when the 20% panels were selected we stopped talking about it!
I can't comment, the panels and the rest of the kit was bought direct by the client, all I know is that they used a wholesale importer to buy the kit because no-one else could supply the Sun panels in the time frame needed, they decided on the solar option after the build on the new modules had begun, so it was all rushed. We just do as they pay us to be honest!
That's interesting, I've heard Sunpower have no stock until June/July so perhaps they managed to get something from a European wholesaler. Sunpower are not (officially at least) available on the wholesale market in the UK, but I don't know if those same trading terms apply to the European market as a whole. Good job to get, there are not that many large installs for Sunpower.
I'll see if I can find out the name of the supplier tonight when in and PM it to you, might be a handy contact for you.
hi new to this,but have installed on these type of roofs.you will have to check if the roof is fibreboard or asbestos the latter is more probable.i suggest hanger bolts into the cross members as a fixing system but drilling into asbestos needs to be contained and supervised by the correct bodies.
Hi All
Am also currently looking at a job of this size and another potentially much larger. Any recommendations/opinions on other panels to use for this size of project. I note from the above that REC are a good choice though my current suppliers do not stock these panels.
I am competent with PV design and installation for small scale projects (up to 15kW) and we specialise in commercial and industrial electrical installation work, but we have never tackled anything this big on the PV front before.
I would welcome any recommendations for good people to speak to regarding sourcing kit, advice on system spec (DC side for multiple strings/fuses etc,), G59, structural integrity, mounting solutions. The current PV wholesalers we use are not much use on this front.
We are Somerset based, PM me if you prefer.
Andy at Sibert for all the Electrical Stuff. Lots of wholesalers such as Spitfire who regulalry contributes here for the Panels.
40kw install
Thread Tags
Tags Tags
install
woko,
SpitfireW'sale,
