Search the forum,
Discuss Eicr in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
sedgy34
Carried out an EICR today few things noted down to do,there is a 10mm equipotential bond on water and gas services. BUT the gas is bonded at the meter under the stairs and 2 inches down it enters the solid floor. also in the lounge there is a small gas pipe that comes out the wall to the fire and a pipe that comes out the wall in the kitchen to the cooker, my question is do i tell customer each point were it comes out in the rooms it needs a 10mm earth bond.
or would you guys ignore it cause its earthed at the gas meter.
i had an assessor raise the reg on corrosion to pipes on a new build but this time its not a newbuild and suppose this is relative to what he said.
kind comments only lol
I think your assessor is talking out of his ars*
It has to be bonded per regs , talk of corrosion is neither here nor there.
I suppose this assessor also requires that where any plastic water pipe is installed a bond is required if it changes to copper again!
There could be concerns if the pipe was entering the building at various points, rather than emerging from the structure at more than one place
Extraneous definition = existing on, or coming from the outside
Reply to Eicr in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Doing an EICR on a commercial install, there’s a copper pipe comes down a pipe chase with the stop cock fitted onto it, it’s then pvc pipes that...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
Did a eicr on a upstairs flat, there is 1 main bonding cable from the consumer unit, the gas pipe comes from the gas meter outside and up the wall...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
