Discuss Admirable AVO in the UK Electrical Forum area at ElectriciansForums.net
The two Voyager craft use valves for the transmitters (X-band TWTs) and they are both still working after 43 years of continuous use under "interesting" conditions!
so you watched Star Trek The Movie as well?
Believe it or not, even into the 2000s many of the police radio transmitter sites were still using an RF transmitter with a valve as the final amplifier. Didn't look very 'valvey' though as it was sleeved with a metal heatsink. Can't remember the type.
This was prior to the Airwave digital system being installed.
Nothing wrong with valves, still a popular technology; you've got one in your kitchen.
I have a couple of big'uns that you might have had some use out of without knowing it. Prior to the digital switchover in 2012, if you watched BBC1 on analogue in London / South East the signal was coming from a pair of 40kW Harris Sigma transmitters. It was the control unit for those that we saw Mark Thompson switch off ceremonially to mark the end of 75 years of analogue TV in London.
You might be able to guess where one of the transmitters ended up. They didn't let me take the mast, apparently that's still in use.
We're not married, but in any case this pic is an old one, taken before we met.
Managed to find a pic of the same dining room shortly after they met...
that's nothing. my missus insists on placing a vase of flowers or some other tat directly in front of the TV's remote sensor, so you need to be a contortionist with the hand unit. then says it's my fault she can't switch from Emmeroids to Eastidiots, to Constipation Street.
maybe it was a condition of sale thea the buyer took them off of the vendor's hands.
It is still very much the case that for very high RF power levels, and/or very high frequencies (in the 10s of GHz and above, not "VHF") that valves are still the best choice in many cases.
Of course when ever you ask for the "best" choice it is very dependent on the criteria you are using for it, and the trade-off changes as technology advances, but they still have a very special place in some areas.
I once worked at Leuchars when it was an RAF base. Doing some not very interesting mundane work in their communications centre.
3ft thick bomb proof concrete walls.
A lot of their equipment still used valves as it wasn’t able to be hacked as well as modern digital electronics could
Reply to Admirable AVO in the UK Electrical Forum area at ElectriciansForums.net
Hey there, I don't normally post much on here but am always browsing through this forum as the topics are somewhat interesting. Anyway, as per...
4K
MikeL1
M
pop quiz where does all that hazardous waste go to wish i didnt know the answer this comes to mind as i; am quite happy to work live when...
P
Got a couple of Q's that any ideas on would be appreciated. Lady down road has 16th Ed CU fitted by her ex husband just before he left her. It's...
Poptasticdave
P
S
Went to look at a cu change today as arranged with the man of the house yesterday:) When i gets there his mrs and daughter are both in the open...
4K
m4tty
M
