G
gavlar
Hi,
Just wondered if anybody could offer some guidance on a fluke 1653b tester.
I was just wondering what the correct procedure is to measure the Pefc and pscc using this tester.
For short circuit test , would this be measured at the the supply intake position on line and neutral ( meter set to loop ?)
And for Pefc , can the reading be used given at socket outlets when carrying out zs tests ?
I have looked at the manual but get a bit confused with which setting my meter needs to be when conducting the different tests
I'm just getting use to this tester at home , and don't want to wreck it !
Thanks in advance for any help
