Discuss Advice on sorting out alarm on new property in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
lecky_bob
Hi,
I have moved into a new flat - back in August. There is an installed (and powered up) ADT PowerMaster 10 alarm installed. I have checked with ADT and it used to be on contract but it is not any more.
I have no idea on any PINs - previous owners not so good on leaving paperwork etc.
Not really sure I want it anyway as it is so easy to put in security using all this new smart technology - I am a networking chap anyway.
The advice I would like please is:
- Shall I just rip it all out? Given all the tamper protection its going to be noisy to do that :) I can access the bell relatively easily so I could warn neighbours and go for it?
- Shall I get ADT to reset it all for me, and put it back on contract? £££
To be honest I want the cheapest solution and I am really not that bothered about keeping/using this alarm. I understand people might want to PM me rather than reply in public.
http://www.visonic.com/Data/Uploads/PowerMaster10_English_Installer_Guide_D-303145.pdf
read this , it would be better to go reset it back to factory conditions.
Won’t work....Tyco who owns ADT and also Visonic made ADT branded Visonic panels, closed protocol. You can’t even buy Visonic parts and add them to an ADT branded Visonic panel if you had full control including engineer codes. I wouldn’t even contemplate taking out a contract with ADT....Best place for that panel, is in the bin.
why not just replace the control panel. the detectors can be re-used, but if eol resistors are used, you may need to alter the values.
They can’t..,The Visonic powermax is a wireless alarm and because they are ADT branded they won’t work with another Visonic panel. Tyco have done this on purpose so you have to basically use ADT or bin the panel. Tyco are the also the shysters who have/are installing the THFC fire alarm which has totally been messed up.
Reply to Advice on sorting out alarm on new property in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
