OP
vambo
Like you've been told, ....a heap of Crap!! Still think less than 15 mins then, sounds like it's going to be a butchers job!! ...lol!!
Quite how you would butcher such a simple job is puzzling me.
Discuss Advice on V Phase Voltage Optimisation Units in the Australia area at ElectriciansForums.net
I’ve come to the concussion our OP hasn’t a clue what he’s on with. ¼ hour to set up? It takes longer to watch the promo video.
Roll on death, it will less painful than reading the rubbish in this thread.
still not fitted it, looked at instruction manual though it is a bit **** it can only handle 8amps continuous. Still a 15min job plus tea and biscuits exactly how I imagined if even easier 50amp MCB feeding unit in 10mm then back feeding my second RCD in cu with a couple of circuits to re-arrange to feed single rcbos
Lol still not a solution, not one. I've been polite and tried to reason my idea of solving my issue.. I don't mind as I understand I've lots of fellow sparks who are exactly the same. Ill not be rushing back using these forums again, I only came on to put forward my problem and idea with this device.
Cheers rednecks
Reply to Advice on V Phase Voltage Optimisation Units in the Australia area at ElectriciansForums.net
