Discuss Am2 inspection and testing I need advice in insulation testing if anyone knows how it's done correctly please? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
What is it you would like to know?
I've just done mine & i did it in 4 sections
Global, dol to motor, ring, light remembering strappers.
Dont forget to remove vulnerable equipment, heating fuse & switch strappers.
It’s good if you know what you’re looking for.
Insulation resistance means looking for ohms...Your trying to prove there’s no connection between cores when there shouldn’t be, so you’re looking for high ohms, so that’s the Mega ohm scale...
There’s an order you should do the testing, but it depends if it’s a new install, existing or fault finding
Thank you for the feedback.
What about CO2 detector can I include in Global as well?
I have watched XS online training videos it doesn't mention to remove the heating fuse,only it saying to keep the switch fuse in off position for insulation resistant testing.
Thank you for the reply.
Actually I am looking for how to do inspection and testing in sequences avoiding vulnerable equipment in Am2 exam center new installation.
There are six circuits 1.CO2 detector with no switched fuse 2.lighting circuit 3. 16A commando circuits 4.ring circuits protected by RCBO 5.heating/hot water 6.DOL motor starter
Main things to remember would be
make sure to operate all switches so all cables are tested...ask them to operate them for you
Before you do the tests remove the detector, disconnect the line or neutral and place into a connector for the lights
If you have your rcbo in place disconnect that as well
And when you've done all these make sure you put the covers back on so nothings exposed whilst you so the test
I think they just said for me to test upto the Central heating spur with it switched off and for the motors etc and dol it was testing upto them and then also testing after because it won't be energised
I had to retake my testing section and failed on insulation initially but the main thing I did the second time was verbally talk yourself through it so they know you understand the process and are competent
As you mentioned that you have done the exam ,there are 6 circ
CO2 did you do Global as well ? Heating/hot wter circuits testing upto switch fuses
Thank you mate!
Reply to Am2 inspection and testing I need advice in insulation testing if anyone knows how it's done correctly please? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I recently just done my AM2 resit and in my inspection and testing, despite the invigilator watching me do the tests, I think I may have forgotten...
Hi all. I recently failed a section of my AM2E assessment. Passed 7/10 but failed on some silly things I'm confident of correcting second time...
Hello all just after some advice for joining a scheme provider in order to self certify work however I don’t hold a test and inspect qualification...
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Insulation test live to earth = 0.7 ohms. This is a long length of buried swa cable (approx 100m) from mains in to submain. Test done with live...
