Discuss Am2 pass / fail in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
Tonydnb
Hi I completed my am2 this morning and just wanted some opinions on wether I passed of failed the mistakes i no I made are listed below
i removed the earth probe before the neutral on one part of my safeisolation
i did a wrong calculation on my regs form for zs all others I measured correctly
I may have not competed by shedule of inspections 100% right I would say 90%
On my faults I found them all but on one description I did not state that it was on open cicuit on the water bonding i just said I had no continuity all other descriptions where okay I think
thanks
hard to say, given what you said you should be ok. they might not like that you got the zs calc wrong as it is pretty basic though, i would have passes with flying colours and finished it before the end of the second day but i had wired the lights which were in conduit in singles when their spec said twin and earth, felt really stupid but had just seen the 2 lads next to me were doing it singles and not thought about it (should have known better since neither knew how to wire a 2w light circuit and went on to fail every section) needless to say i resat the practical which took me less than a day so not so bad
There is an alllowance for some mistakes, i mixed up a pair on the cat 5 section and passed.
I also forgot to do the functional test on rcd (press button) and passed inspect & test section.
I also know a boy and his heating system didn't work and he passed.
It is done now no point worrying about it.
thanks
In bold........you will not fail for this...best practice to take lead of earth last BUT not part of the safe isolation procedure.
Reply to Am2 pass / fail in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi all. I recently failed a section of my AM2E assessment. Passed 7/10 but failed on some silly things I'm confident of correcting second time...
Hello everyone. I've been reading stories of people failing their AM2 on section B initial verification. I'm going back in my head and I think I...
Finished my AM2 the other day, pretty confident with most of it except the testing. When I done my live polarity, Ze and PFC tests for some odd...
resitting Saturday my am2 4 sections a3/b/d/e swa and sy failed on protective conductors on both swa i under stand thats the earths i...
Hi all, hoping for some advice, I’ve recent resit my AM2s after failing on first attempt… I’ve passed all my resit apart from section C just on...
Electrical Courses
