Discuss Anyone recognise this socket? in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
It's a new safety design. If you just pull the plug out without switching off the appliance...(no switch on socket) it just flashes a warning blue flash...and falls out of the wall!
The earth is provided by a bolt through the centre of the outside part, and there is a brass bar floating between the phase and neutral, until it is tightened up by the bolt. The bolt is retained by a plastic washer which shears off easily if overtightened...result is...pull the plug out, watch the fireworks and call an electrician!
Or, buy a proper socket and fit it!
Just Googled them, they appear to be Chinese or from that area and do multiple types of sockets in a similar format.
Don't blame the Chineese for this one.
From the Simon Website , they're Spanish;
A small workshop set up in Olot (Spain) in 1916 was the start of what today, 100 years later, is the Simon Group: a family company that has grown for four generations,
They probably have the crap made in China tho'
Thank you all for your input! The electrician is coming next week, and I have told the manager here that I want bullet-proof, and not a re-hash of this cheap crap...he said "they all use this stuff" so I went to the local hardware supplier and got a nice new socket and left it to be fitted...
I won't be back for a week or two, but I will check it out carefully when I return...I have also asked for the CU (separate post) to be fully checked.
Yes, next week..and it's not hanging out now, cos I stuck it back in with Blu_Tack...it's in Spain, so not to any BS standard...and I locked the MCB with a wee bit of thin wire taken from a sobrasada, so all good!
Incidentally, it used to be a "lighting socket" which is a 2 pin jobby with a wee fuse carrier with a 1A glass fuse, used for a table lamp. That got broken by an enthusiastic Hoover-wielder, so the spark replaced it with a "proper" earthed socket...which as you can see wasn't of the best quality...odd really, to have a "lighting" socket as the cable feeding it was both heavy enough and had an earth to be used for everyday appliances...but anyway, it's an insert, and poorly made...
I did query it at first, but the spark showed me the JB and gave the screw-nut an extra tight twist, so nothing to worry about there!
I showed him a Wago but he wasn't keen...WayNot To Go, I guess...pero mi Espanol no es bueno, so I may have misinterpreted his raised finger...
Yes, I have, I taped over it and put a notice saying not to use it. However, there's no-one in the place, and the manager has the only spare key. I'll update things when I next get out there.
Makes me see how well made most of our sockets are, and what a good design too,in the main.
Reply to Anyone recognise this socket? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
We are having issues with our electrical system. In the garage, dining room, kitchen, one of two bathrooms, master bedroom and the front yard...
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working...
