Discuss Bahco snips the best? in the Electrical Tools and Products area at ElectriciansForums.net
i use CK myself. not tried the bahco. bought a pair of the " ergonomically designed dog's nuts CK ones, them with an angled head. load of pig manure.
ck man myself like the 1.5 an 2.5 cutting bit im so used to them now when i pick some up without the stripper bits i strugle with them .
havent usecd snips since the crap toolkit we used when i was in the army college. I use the cutters below. Will cut and strip upto about 35mm easily. i only use snips for cable ties, and then i use the carpenters pincers.
F3XMR8lJxtoaZiuizNYCV_bbcfbnQ6wYwJ-zKsA78nSR5IASr3jGXmEGlIRSVCrRpvNInwpVG5CNDDDaSv5ADRlYHm2ceNtABFmPaCfxOW9KUIqV929SFCFT6FK-vRaeqkiFg0LZJFtc5glzznHi4ldmyy2hGBiUyRE_GqR2VSKgF1X6-A
I use one of these mostly for cutting and stripping cables.
I only seem to use snips for cutting cable ties and cutting in close to other cables.
I'm trying to figure out if that means they're good or bad.:confused:
Hi Marvo, I think you'll find that it's both in the one statement. i.e. 'dog's nuts' usually refers to something being perfect etc. 'pig manure' means that they're not.
So they were supposed to be but in reality they're not. as with a load of things in life.
Cheers,
Lofty.
i was looking at these, there is two differnt sizes tho.. and seem ok at around £20, am i coreect on this
Reply to Bahco snips the best? in the Electrical Tools and Products area at ElectriciansForums.net
Have run out of stock of RJ45's and looking to get a bulk pack online, it's been a while since I've had to buy any and I'm mostly seeing packs of...
Hey guys I'm studying at college at the moment. I am looking to get some essential electrical testing kits slowly. Is a multificunctional tester...
Hi question whats my best route ive just done the am2 and past my nvq has expired as i took a while before completing the am2 i have level 2...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
