Discuss Ceiling Rose Wiring - 3 core plus earth ? in the DIY Electrical Advice area at ElectriciansForums.net
Advice needed,
Removed a ceiling rose and the cables must have been loose as they all popped out. Connected up all the cables apart from the grey cable. My PIR light outside is now not working without this grey cable connected into one of the blocks which is fed off the same switch bank on the wall. I believe the grey cable should go into the live brown block. Any help appreciated.
Hi - unfortunately there are several ways this could've been wired up, sorry.
what in your hand with a screwdriver never .;)test equipment is in order .Is Kentucky chicken near you I mean sparky chick .just wait and her lady ship will be along any moment.:D
I have shown 2 sparky's and both are unsure what that grey cable is for. But like I stated earlier the outside PIR light is not working now so must be linked to that
Was the PIR light ever switched or was it permanently left to its own devices.
  • Agree
Reactions: 123
I could guess at the most likely correct hole for it. :)
If it were me I'd want to see the other end of it to make sure.
If your wiring is falling out of the terminals I'd suggest getting it checked.
New build cowboys i think
Not even a mention about the earth sleeving? My my my...:(
only connected temporary until I can work out where that damn grey cable go's and then will tidy
Reply to Ceiling Rose Wiring - 3 core plus earth ? in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
